Old 09-10-2013, 07:53 AM   #10
soucorp
soucorp
soucorp's Avatar
If you smell coolant, its most likely a leak, therefore causing your engine to over heat. The leak could be from an old hose line or cracked coolant reservoir or radiator. Have it checked out and do not drive the car if you see engine lights flashing and temperature gauges going redline.
Live and learn kid, alot of common sense goes along way, take the proper time to read about how your car works -you know the owners manual !
Best
soucorp is offline   Reply With Quote
