Originally Posted by 3point2
I pulled each fuse and all the readings are at 1.70 amps. No big fluctuations anywhere.
Is that ampere normal?
No it is not .
1.7 mA is normal .
Are you sure you're reading it right ?
If the meter you're using now is the same as the one you posted a pic of earlier , what are you set to in the dca range ?
