Old 09-08-2013, 04:40 PM   #6
Cloudsurfer
Originally Posted by j.fro View Post
For the rear, Boxster and 911 suspensions are completely different and the struts will not swap.
For the rear, the strut bodies are the same, but the spring rates are not. If your Boxster struts are toast and the 911's are good, you should be able to swap the Boxster coils onto the 911 struts.
From handling these, but not comparing them to each other, I think you are correct here on a "base" C2 or C4, but the Turbo and C4S use a different upright, so I think all of that is different there.
Either way, the damping values are all different, so even if they did fit, and you swapped springs to the correct rate, it's still not going to be a good setup.
Likewise, you could use 996 C2 front bits, but not C4, C4S, or Turbo bits.
The whole thing is a bad idea.
Boxster S
