Tabs, that is the term I was looking for thank you sir. Took the idea from my fiberglass aftermarket bumper. Has many of those to hold the mesh.
RE hot glue or not. Your guess is as good as mine. I bet the air filter is strong enough for a little tab but you never know. I would personally bother to use good A/B epoxy but given you degrease the housing with brake cleaner (for instance), that should ruff the ABS plastic enough so the HOT glue stick almost permanently. Dunno, not 100% sure.
I'd say epoxy if you ask me.
