It is within range but how long did you leave it running for ?
it could drop off after a while so put your lights on and keep it ticking over for a while .
what meter did you get.
This type of scenario is why i use flukes with min/max and logging etc.
next you need to disconnect the ground and put your meter across battery- and disconnected - clamp wthen close everything .
This willtell you what your drain is running at .
