Old 09-07-2013, 02:04 PM   #7
dghii
You can get electrical contact cleaner at Walmart or any auto store. The top control relay looks like a large (double sized) relay toward the top right of your fuse panel. It will have a white label on it.
Pull out the top control relay and spray the electrical contacts with the cleaner. You can also spray into the relay socket in the fuse panel. A little spray is all you need.
Give it a shot. Make sure the relay is fully seated in its socket when you reinstall.
