Old 09-07-2013, 06:58 AM   #159
recycledsixtie
recycledsixtie
recycledsixtie's Avatar
Originally Posted by Mikelove View Post
How many times to do see an aircraft engine fail with good results? The warning lights flash and a siren goes off, then its bang ! I think the gurdian is a waste of money
I disagree because when there is sufficient metal in the oil plug sensor then the light/aural warning will come on to warn you of more disastrous results that could result if you kept on motoring....
True damage may have been done at that point but I believe it is worth it to save the engine block.
