Originally Posted by 3point2
Thanks for the replies.
No battery light came on. It drove fine on the way home the last time except the radio died. And then when I came home a few days after the car was parked tor restart it, the battery was completely dead. Can the battery completely drain that fast on its own even when the car is turned off?
I'll pick up a voltmeter and check the voltage tomorrow.
What is the earth connection? Where is it located?
Thanks again!
He meant Ground cable. The black cable at the battery terminal. If you have a volt meter connect your wires in series from the neg cable to the negative battery terminal. If there is any voltage drain it will show on your meter. You can disconnect your fuse 1 x 1 till you no longer see any voltage reading with the voltmeter.
I'd start with the radio fuse first.
