Old 09-06-2013, 01:01 PM   #2
BYprodriver
BYprodriver's Avatar
Yeah, brake light switch can get loose on you. If not that maybe a little solenoid that prevents shifter from coming out of park unless foot brake is applied. Had a Land Rover Discovery pull that on me in the middle desert. Maybe that's why they named it Discovery?
By the way usually you can pull off the shifter trim plate & manually unlock the solenoid if that's the problem.
