If you do not do the reset routine will the car simply use the baseline that is already learned by the ECU?
I disconnected battery to do some door work and I just restarted, drove around the block to make sure the car ran ok. Then drove to work the next day.
Curious thing is that a few days later it appears my Fuel pump relay went bad.
Coincident or cause?
I hate when I try and do the right thing and get smacked down
Seal Grey
