Are you running the proper oil level?
Are you running the proper oil viscosity?
Mileage?
I suspect your AOS is on the way out. Not major. This is a maintenance item.
A "puff" of smoke on occasion can be normal. You said yours is showing a "surprising amount", so this sounds less normal.
