Johnny, if you can stop it by putting pressure on the tailpipe then simply take the car to a welder, add that same pressure you are talking about, and get him to do small welds around the connecting pipes at the same time you are pressing on it. That should be enough to retain the tension.
A temp fix yes but maybe you'll be lucky and it will last eternally!
