Old 09-03-2013, 07:37 PM   #6
heymanwatchthis
heymanwatchthis's Avatar
Thanks everyone for the responses. When I had IMS upgraded the clutch was replaced and bearing etc serviced. Tomorrow I am taking it back to the shop that did the work to put on lift and check out the car. I am also having them replace the motor mount - in the video you can see the exhaust tips move a great deal - motor mount is likely shot and causing a lot of motor movement. Will see how this works. If the exhaust has a rattle inside, will present a perfect excuse to install Top Speed exhaust and secondary cat deletes! I will post after visit to shop tomorrow.
'01 986S: LN IMS, PedroBar, PSS9 coil-overs, underdrive pulley, 997 short shift, GT3 console delete, Crios muffler mod
heymanwatchthis is offline   Reply With Quote
