Old 09-02-2013, 01:53 PM   #12
BYprodriver
BYprodriver's Avatar
Originally Posted by thom4782 View Post
If the parts are plastic like and you conclude it's normal wear, check your camshaft deviations to see if the wear is excessive. Anything greater than +/- 6 degrees is out of spec. If so, then you should consider changing the pads.
The parts in the picture are from my Box @ 88,K miles & another engine with less miles & less oil changes. So around 60,K miles is a good time to change the Vario-Cam chain wear pads to the updated parts that last much longer.
