Old 09-02-2013, 09:01 AM   #12
Cloudsurfer
If you dont oil the cylinders before storage you will likely have rust in the bores after a number of years which will need cleanup before turning over the crank lest you score the cylinder and bust rings and loose compression.
I like the engine bag idea too, along with the oil fogging in each cylinder and put the plugs back in
Aluminum- Alusil/ Lokasil/ Nikasil bores don't rust.....
The rings can, though.
Boxster S
