Thread
Oil Pan Debris. Beginning of the End?
09-02-2013, 07:17 AM
11
thom4782
If the parts are plastic like and you conclude it's normal wear, check your camshaft deviations to see if the wear is excessive. Anything greater than +/- 6 degrees is out of spec. If so, then you should consider changing the pads.
thom4782
Find More Posts by thom4782
