Old 08-31-2013, 11:00 AM   #17
Gilles
Most likely either a worn throw out bearing, or a weak input shaft bearing on the gearbox.
JFP:
Could be possible to replace the input shaft bearing by removing the transmission case but leaving the gearbox installed..?
In some gearboxes, the casing for the input shaft bearing is cast inside the transmission housing.
