My first post, just joined.
Hi all, i was researching green bits found in the oil filter on boxsters, because i found some in mine today after reading that you should pull the filter apart and inspect it. I have a couple of orings leaking around the spark plug seals, wondered if it could be the source of these green bits, one piece was like a worm and stretched! Although that was brownish red. 2000 boxster s with 95,000 on the clock. New waterpump, and air mass sensor. Have owned it for 3 years, done around 12,000 miles in it.
