Old 08-30-2013, 10:20 AM   #15
stephen wilson
A prop. valve to the Front sounds like a very bad idea. What if you have some brake issues and need to really press on the pedal, you won't have any extra line pressure available. The "proper" way is with a balance bar(dual masters), or replumb the system without the ABS, with a prop. valve on the REAR brakes. You could also try mixing brake pad compounds front-to-rear.
