Lawrence told me about this thread yesterday, my setup It's nothing fancy. Just disconnected the whole abs and ran a proportioning valve to the front calipers to limit the work that they are doing hence change the brake bias.You can play with this set up till you get it to brake to your liking, in the end I would like to run a dual master cylinder set up but for now it works fine.
