Congrats to any would be owners who are thinking about buying a Boxster and reading this thread. I got a PPI done before I bought my car. A more in depth PPI I believe is required.
The basic PPI does not include the following but I and am sure a bunch of others would agree and some have suggested the following in addition:
- remove oil filter to check for metal
- drop oil pan to check for metal
- a leak down test
This list is not all inclusive.
My experience after 2 years of ownership is that the Boxster is the most fun car I have driven in my life. However it comes at a price. I do not think that it is a durable car in terms of some components. There is always the possibility of IMS failure. Have had CV joints refurbished, idler arm replaced and if I keep the car long enough wheel bearings replacement. This is on a car with only 40k miles. My car is a Boxster base 2001.
Before you buy this car you have to ask yourself if you should have enough $$$ in the bank to budget for a failed engine plus 'normal maintenance' of about $2k a year.....Hope this helps!You cannot run a Boxster for the same cost as a Miata.
