Old 08-29-2013, 08:49 AM   #13
bella986
bella986's Avatar
found my problem thanks to your combined guidance. it ends up being a deteriorated joint rod retainer clip , exactly where sb01box suggested to look. Any idea where i can find the plastic retainer clip, parts schematic does not show it, only adjustable joint rod, OEM 986 424 931 05 for rod assembly, hoping to purchase just the 5/8" diameter push retainer.
took console out to better understand cable-shift operation, found another interesting surprise. as there is a slit between the ashtray and console, the ashtray being used for coins, they tend to fall through. found 16 years of loose change!
bella986 is offline   Reply With Quote
