Old 08-29-2013, 08:47 AM   #1
The Radium King
The Radium King's Avatar
check the tool you need to get the fill port open - if your car is a five speed you need a 16 mm XZN triple square bit. it would suck to get the fluid drained and then not be able to fill it back up. on that note, you'll also need something to lift the fluid up to the fill port; most use a suction gun.
as stated, the oem fill is the most accepted approach here, but some also use redline 75w90ls. beware, however - transmission fluid generates as much discussion as 'what oil to use' around here.
