Old 08-29-2013, 07:43 AM   #1
paulv
I don't know if the older version of Durametric has Freeze Frame data access. If so, check that and post it here. Misfires are not necessarily caused by ignition issues -- can be mechanical or fuel delivery problems. Also, go to the actual values section on the Durametric and watch the misfire counts for that cylinder at idle and under higher rpms.
Regards,
paul...
paulv is offline   Reply With Quote
