Old 08-29-2013, 04:51 AM   #1
paulv
Originally Posted by 993innc View Post
So...........
The car I bought has issues.......I knew that. But now I'm stumped.
The has thrown codes P0107, P0300, P0343. All data has everything from replacing the variocam to testing for bad grounds from the DME to cam position sensors, to replacing the DME
TIA
Check with your tool which DTC set the CEL, then go from there. Also, you can view the misfires as the car is running. Do you have service info? Because you're going to need what the test criteria is before trying to correct the code(s).
Regards,
paul...
paulv is offline   Reply With Quote
