Old 08-28-2013, 06:19 PM   #1
The Radium King
The Radium King's Avatar
ps pulley? I presume you are talking underdrive pulley (udp)? if so, then you can delete the ac and just run a shorter belt and still maintain the factory belt routing. if you delete the power steering as well then you need the ac delete pulley in order to maintain the appropriate belt routing (or gut your ps pump and use it). the ac delete pulley is designed for the dfi engines that have a different belt routing and require the pulley if the ac is deleted (like in the spyder and cayman r) but the ac compressor is the same for all engines so the ac delete unit will work on our cars. suncoast and I think bgb sell the oem unit; you can also buy the gsr unit that mounts in the ps pump location.
