It will start when cold only. Last night I started it, cleared the codes, and let it run till it died: about 15 min. warmed up to 180 degrees then died abruptly. Then an immobilizer failure code appeared. Will a car start at all if the immobilizer fuse under the drivers seat is blown? I'll test and clean the MAF, too.
