If yours are "flaky" looking as mine were, you may need to wet sand them with #1000 and then work your way up with finer grits and buffing compounds. I found it much easier to pull the headlights and strap them down to to a work surface and use a power buffer for the final stages. I have a plastic restoration kit with two grades of polishing compound.
