Old 08-26-2013, 04:41 AM   #7
Wret
I was a little nervous about tackling the job after reading about how hard it is to get too. I'm not as flexible as I used to be. The only fairly difficult tasks were removing and replacing the bolts, because of the angle. Mike Focke's write-up suggests cutting the little bellows tube and and dealing with the spring clamp when you can get better access (after removing the old AOS). Mine had a screw clamp so I didn't have to deal with a spring clamp, but this seems like a good bit of advice.
Wret is offline   Reply With Quote
