Old 08-24-2013, 04:31 AM   #11
haz
haz's Avatar
Here are my replies to you guys.. I will send the particles to a Porsche specialist for an analsys on monday..Looks like I have to save up some serious $$$$
Looks like it sticks to a magnet, so itīs not aluminium..
Originally Posted by ilikeching View Post
Hi Haz,
Check this worshop nearby, Porsche | SS Performance
They quoted me 20.000 NOK / $3300 for a IMS replacement... NOT inc the part itself.. I got that quote a few weeks ago as I was curious on that cost if it were to ever happen to me....
Haz you need to cut the ends off the filter & open the paper out flat so you can see everything in the filter. Drag a magnet across it to see what sticks. It doesn't look to bad, most of what we see looks like silicone sealant. You should have the shop remove the oil sump pan to see what is there & clean the oil pickup tube screen.
Post pictures with a small object so we can reference the size of the particles.
I did that, see pics below. I already picked the car up, and the mechanic said there were metal particles in the pan as well...
It sounds like your engine has other problems from possibly bad maintenance. Although that's not certain.
It has a proper servicehistory. Same mechanic for 7 years.
Originally Posted by trimer View Post
Did you stick all that up to a magnet and see if it sticks??? A lot of that looks like plastic?
Went out to pick up some magnets now.. and yes it sticks
Originally Posted by runjmc2 View Post
If you have ANY chance of getting your money back do it! I have a dual row and was felling pretty good (based on the law suit reported failure rates), until I recently had the opportunity to hold a failed duel row in my hand....from a low mileage car. That metal does not look like IMS to me....but listen to Jake and the experts.
Why does this not look like IMS to you?
Does Norway have a guarantee time for used cars?
The build date on US cars is on the driver's door jam. Where the door closes.
Dual row cars are the most unlikely to have an IMS fail. Some 2000 cars had dual row. But Porsche's serial numbers are not reliable to determine this.
I donīt think so. I bought the car july 4.th from a private seller.
Here is a pic from my door. Is this the engine number? e1398/140020
haz is offline   Reply With Quote
