Old 08-23-2013, 03:14 AM   #4
Steve Tinker
Steve Tinker's Avatar
If the metal debris is non magnetic, there's a good chance that the big end /main bearings of the crankshaft have been compromised....
Run a magnet over the metal in the filter - if it stick to the magnet, its ferrous, which could be debris from the IMS ball bearing, timing chains / sprockets etc.
Even after 10,000 miles, there should be no metal (or plastic from the guide rails) in the filter - you need to determin the source of the failure asap.
2001 MV Agusta F4.
