What to do, what to do......
#1 - Do you have confidence in the workshop inspecting the filter?? how long since it was changed ??
#2 - Go and look at the offending filter - determine how bad it is.
#3 - Is the metal in the filter ferrous (magnetic) or aluminium /white metal debris - this could be important.
#4 - If the filter debris is exessive, have the workshop remove the sump cover plate and inspect the inside - if the filter is full of metal, there could be more in the sump which could indicate where the failure occurred ....
2001 MV Agusta F4.
