That's great. I have this problem too. I can see the spring that you guys are talking about. I tried spraying some WD-40 to get rid of the noise. For some apparent reason, my friend says that it is the entire clutch that is worn out. Though the clutch is a little stiffer than it probably should be, I dont think it's the ENTIRE clutch wearing out. It's got to be the SPRING and the plastic piece rubbing against each other. JUst my 2 cents.
