Old 08-21-2013, 12:51 PM   #4
dbansal
Originally Posted by madmods View Post
If like me you get a cloud of condensation on the bonnet (located just above the cap) then you are okay to assume that your cap is defect. Mine is like that at the moment.... I just forget to order one every time (thanks for the reminder!).
If you have no cloud then the problem may be a bit more severe. Leaking hose, tank, rad, or even a crack head/gasket. Get a pressure test done to be certain I'd recommend.
also... if I had a cracked head/gasket... pretty sure I would know??
dbansal is offline   Reply With Quote
