Old 08-20-2013, 12:34 PM   #2
JFP in PA
I have seen this before, check you crank position sensor as some aluminum flywheels do not have the correct spacing between the CPS and Hall Effect teeth on the back of the flywheel. This has sometimes caused actual wear on the end of the CPS.
