I am a volunteer Tech Inspector for our PCA section here. Some driver's do thier own tech inspection (Self Tech), while others take their car to a shop (smart move) for a more experienced/thorough inspection. Those shops will stamp and sign-off on the Tech Inspection Sheets.
At the DE Event, the Tech Team re-inspects the car, and we sign-off again, so your can be assigned run-groups, and the required windshield stickers.
Regardless, make sure you have had a brake fluid flush prior to the event, thick brake pads, good rotors, and good properly inflate tires. Wheels torqued to at least 96 ft.pounds.
Your helmet (not a motorcycle helmet) needs to be at least 2010 Snell certified.
We also require, long pants, long sleve shirts. No synthetic fibers. Check with your region's rules.
Have fun. Be safe. Be humble.
