Old 08-19-2013, 10:40 AM   #18
RandallNeighbour
Originally Posted by evo-r View Post
So I brought the car to 2 different shops and one thinks it's some bearing in the differential and the other thinks it's the rear passenger wheel bearing. I'm thinking it's the rear passenger wheel bearing because when I sweep the car left and right I only hear the noise when I sweep to the left and the noise disappear when to the right.
Is it possible that in this case some bearing in the differential is bad as well?
A good way to isolate the problem is to jack up the back of the car (both sides), put it in neutral, leave the parking brake off, and rotate the wheel as you listen carefully to the source of the noise.
Another thing you can do while the back end is up in the air is grab the wheel and pull one side and then the other toward you, then the top of the tire and the bottom of the tire. If there's play and slop in the wheel, it's a wheel bearing.
