Old 08-18-2013, 06:25 PM   #3
Mark_T
I think that what triggers the brake wear light is the open circuit resulting from the sensor having worn through. I don't think that it is from the sensor closing a circuit via contact with the rotor.
If you want to get rid of the light your need to connect a new sensor. Whether you install the sensor in the pad or wire it up out of the way is up to you.
'99 black 986
