Old 08-17-2013, 12:27 PM   #2
JFP in PA
Originally Posted by jgonzalez114 View Post
I'm in need of the passenger side valve cover for a 2003 Boxster 2.7L. I saw on ebay for a 2001 for $100 but it does not fit. Needs to be for the 3 timing chain engine. As you can see by the photo, on the upper left side of the cover there is a huge hold from the cam chain forcing a broken bolt out of the cover. If anyone can help locate a used or new please let me know.
Thanks,
You do realize that the cam cover is 1/2 of the cam support saddles, and that the head and the cam cover are machined for the cam saddles center line while bolted together as a unit, which means you cannot change cam covers without also using the matching cylinder head. Sorry.....................
