Evo- Asking what else you can change out when you swap a wheel bearing is a slippery slope.
I did that and ended up replacing all four struts all the control arms, the drop links, the brake discs and pads, the brake lines for braided stainless...
This is where spending money on your car and go from expensive to outrageously expensive.
However, my situation was very different from yours. I supplied my own parts to my Indy any charge me a flat $100 per hour. Wheel bearings, coil overs, drop links and control arms all the way around including labor was about $3500.
