Originally Posted by mikesz
The cooling fans on my 99 Boxster are not working properly. I removed the 4 relays and got a jumper between the 87 & 30 connectors neither fan worked at low speed. the left, drivers side, worked at high speed. The right did not work at high speed and keeps blowing fuses when "jump" high speed. So at the very least sounds like I need a new resistor for the left fan. is there any way to be sure? What should I do about the right fan? I was going to remove the bumper to clean between the radiator and condenser. Has anyone replaced a radiator fan? How difficult is it?
How did you know they weren't working?
