Both my ballast resistors were broken. Because I knew both fans worked on high speed, I replaced the resistors by splicing them in place of the old wires. I mention this because you'll want to clip the old wires near the old ballasts. The make sure you leave enough on the news resistor wires so you can easily splice in the wire connectors. Hope this helps. BTW: I didn't need to remove any fan or bracket parts to do this - just the fender liner.
