Old 08-16-2013, 11:50 AM   #2
Gilles
Raven, you may want to soak them with PB Blaster and you 'may' have to use a ball joint remover if it's too stuck, after all if they are the original ones, these would be about 12 + years old...
Originally Posted by t_raven View Post
This may be a dumb question, but I cannot find any help on replacing my rear drop links on my 2001...
I ordered and received the new parts from Pelican, and I can get the nuts undone on both the upper and lower connectors, but I cannot get the upper shaft to come out...
I have read on here that this should be a 15 minute job, so if anyone has a trick to removing the end that connects to the shock I would appreciate the help..
I am trying to do this replacement right now so urgent help is needed....
