Old 01-26-2006, 07:01 AM   #17
wild1poet2
The $40k must be for the RUF conversion. You could probably get the swap for a lot less at a local shop. Some will install conversion kits I think, others will use engines from salvaged cars. These guys do it;
www.autosportengineering.com/3.6_conversion.htm
I don't know the price but got to believe it's less than $40K. From what I understand these motors also experience RMS leaks. Makes sense since I think the blocks are the same. Although I am guessing the crank is different for the longer stroke. Crank bore's probably the same. Can someone confirm?
'04 Black Boxster, 18" Carerra wheels
"If you're not living on the edge, you're taking up too much space."
wild1poet2 is offline   Reply With Quote
