Thread: surgery update
Old 08-08-2013, 12:53 PM   #12
trimer
jakesbox
trimer's Avatar
Originally Posted by Dave S. View Post
Sounds like you can drive her with confidence now. That window regulator can easily be fixed without removing it from the door if you want to take on a very minor repair on your own. See this thread:
http://986forum.com/forums/general-discussions/25704-window-regulator-permanent-fix-stretched-cable.html
that is a great fix. how do you know how much to adjust the cable when you put it in there?
I just bought a brake cable to use to stick down through the drain holes so I think that part is on the other end!
