You will be surprised at how much you can do . I would recommend The 101 boxster projects book . You can also do the front motor mount and a 997 shifter also and if your up to it you can do the ignition switch, cv boots , wheel bearings , under drive pulley , cat delete , exhaust , ROW suspension. The list goes on and on.
