You will need to bleed the clutch from the slave cylinder on the transmission.
Be prepared for a rather difficult job unless you have 3 arms that are 4' long......
I change out my clutch fluid every 2 years and find its easier to remove the rear wheel, the bottom alloy engine plate and the left hand side angle cross brace for easier access.
2001 MV Agusta F4.
