I'd try bleeding it first. Are you sure it wasn't the brakes that were stinking? If the brake fluid gets too hot then they'll often need to be bled after they've cooled. Since the clutch and brakes use the same fluid, this could be the problem. The last half of the clutch return is exactly what goes limp when there's air in the system.
