Camshaft deviation????
Ok hooked up the durametric, lot of interesting information. I read the codes and same codes as before. 300,301,302,303, 341,1313,1314,1315,1319. Plus I checked the camshaft deviation #1 is .25% and # 2 is -.4% is that normal?
the car has a misfire/rough idle around 1000-1200rpm with an associated noise like a rattle or a chain flapping.
I've checked the wiring, checked the coils, and the plugs, the AOS has oil in the tube going to the TB. I've cleaned the TB and the MAF sensor. replaced the air filter and fuel filter. No Help. I need HELP!!! please.
