Thread: turbo 986?
Old 08-05-2013, 09:44 AM   #3
BYprodriver
BYprodriver's Avatar
Originally Posted by reiver View Post
Why not change compression ratio? I am not looking at it due to possible heat and space issues in the Boxster.
The proper way to add forced induction is to 1STinstall cylinder sleeves & stronger pistons that also lower compression. This requires total engine disassembly, so basically you need to rebuild the engine, while you are "in there". This will cost $10,K+. Naturally you will want to start with a 3.2L+ engine for max power, so now you have 300+HP & 280+ ft/lbs torque with is plenty for any 3000lb street driven car.
Now if you want to add power,complexity,heat,cost & lower reliability to your car forced induction is the next step.
